BansheeBoy96 Posted August 1, 2011 Report Posted August 1, 2011 Changed the main jet to a 45 the Shee idles now pretty good May be just a lil rich but not much.....bit now my problem is i got the main jet right the pilot right now when i pinn the throttle n first and second gear she has a slight bog at first and Shee never had that bog before.....so now Im thinking the needle needs to be adjusted or changed what u guys think.....just got done rebuilding and adding ported n polished cylinders n hot rod stock stroke crank and removing the air box running uni pod filter on two into one carb...... Quote
camatv Posted August 1, 2011 Report Posted August 1, 2011 doubt you put in a 45 main jet.. try asking the place the did the "port and polish" to your cylinders for jetting specs.. Quote
BansheeBoy96 Posted August 1, 2011 Author Report Posted August 1, 2011 35mm carb two into one yea i put a 45 in it had 52 but was to rich alot of white smoke wouldnt idle now it idles n no smoke with 45..... Quote
volcrano Posted August 3, 2011 Report Posted August 3, 2011 yeah u put in a 45 PILOT jet not main jet.if its bogging it might need a 48 or 50 pilot.u should only go down one size at a time in jetting.ur prob tad too lean. Quote
sleeper06 Posted August 7, 2011 Report Posted August 7, 2011 If it idles ok leave it put a 195 main jet in it,needle plays a huge roll on a single carb set up,if i remember correctly i used an eek 4th clip i would try adjusting your needle go rich first if it takes the fuel leave it rich ,do a plug chop with the main i stated an adjust from there,a ported bike i built ran a 200 main with pro circuits in winter with that carb set up Quote
