Well I done my first compression test. I bought my 99 shee from an older man who was the original owner. The compression showed just over 100 on the autozone special comp tester.
I guess I will take it apart tomorrow(first time) and have my cylinders checked. Im sure they are fine and I can get probably get by with a new set of rings and gaskets.
Where is a good place to buy the parts?? And shoud I just buy new pistons?? LMK what you guys think I am gonna tear into it tomorrow.
First,did you do the psi test right? hold the throttle Wide open and kick it till it wont go higher,like 20 times.
Have your cylinders checked for roundess,see if you can get away with a hone.If i just needed rings and hone,i would buy the parts wherever,rmatv/wiseco ect.
If you need to bore:
I use WSM pistons from ebay,last set i bought was .020 over coated for 120 bucks. I have used them in all my bikes and have never had problems!
Edited by Burt Reynolds
The most important thing about getting them checked is taking it to someone with the right mics to test it. Meaning if you hand it to someone and they only check with with a slide type mic caliper,like an autozone one,then they arent doing it right. Its best to take it to a machinist
X2 on the WSM Pistons if you do have to rebuild I highly recommend. Here is the ones I went with and I think they are better than Wiseco. http://cgi.ebay.com/ebaymotors/Yamaha-Banshee-WSM-ATV-Forged-Piston-Pair-Bore-64-5-_W0QQcmdZViewItemQQhashZitem2c4beacfffQQitemZ190252240895QQptZMotorsQ5fATVQ5fPartsQ5fAccessories
Thanks I noticed you are in Tn as well. Im just south of columbia. Where is scott county?
I am about and hour from Knoxville. I live in Robbins so its to the NE from were your located at. And about 3 and a half hours also.
