Ok ... here we go ~
95 banshee
new top end with cool head
boost bottle
cylinders bored 10 over & ported
new air filter (cover removed)
main jets 280
stock exhaust
new spark plugs ~ both getting spark
plug check looks good
compression 160ish on both
It takes me about 20 or so kicks to get this thing started -- after it has been sitting over night
Runs great once it is started ---- but I can't fihure out what the heck is going on.
Cleaned out the carbs just to make sure --- and they looked good .... BUT I noticed that the reeds don't fit tight --they have a slight gap. No cracks - just not a tight seal like my other banshee. I flipped them -- but didn't make a difference--still a slight gap.
Is it possible that the reeds are causing this starting issue??
Any other ideas???
Please help -- THANKS!!
Mimi
Ok ... here we go ~
95 banshee
boost bottle
main jets 280
stock exhaust
Usually flipping the reeds over leads to them breaking off. If you have stock exhaust, a 280 main jet seems AWFUL big. Have you cleaned the carbs lately? Do you have the choke tube between the carbs in place? Are the float bowls on the correct carb? The float bowls are different between the left and right carbs. What size pilot jets do you have and where are your air screws set? Is the spark bluish white or is it orangish in color?
Edited by bansheesandrider
[why do you have ported cylinders and stock pipes???
if its hard to start it either needs plugs, or the choke is not working check that the bowls are on right
LOL... ummm yeah -- stock exhaust seems a bit stupid --- but I had Duncan High Revs on it & swapped those over to my 1998 Banshee :)
ok -- carbs are cleean --- float bowls are on correctly --- spark plugs are carmel brownish in color --- pilot jets are stock 25's --- air screws are at 1.5 turns out
When I did a spark test -- it was whiteish in color
I understand everyone thinks my mains are too big --- but since my spark plug check shows a good color -- I thought I would be ok. Even if the mains are too big -- how does that impact a starting issue? ??? If I jet down --- where would you suggest I jet too?? 250's?? lower??
Thanks!!!!
Thanks!!!!
Do you have any bad exhaust leaks?
Edited by jlsparky7
No exhaust leaks ...
I did end up swapping out the reeds .... and she started on the 1st kick!!!!!
what a headache -- but always worth it when it finally runs great!
Thanks everyone!!
