shakar Posted July 23, 2011 Report Share Posted July 23, 2011 when a crank is trued and welded .do they only weld the out side pin? or inside also ?ive seen one fs seems to welded in and outside ?? thanks for any input Quote Link to comment Share on other sites More sharing options...
CFH87 Posted July 23, 2011 Report Share Posted July 23, 2011 As far as I've seen is they only weld the outer like I had mine done. But they may also weld the inner too not 100% on that. Quote Link to comment Share on other sites More sharing options...
shakar Posted July 23, 2011 Author Report Share Posted July 23, 2011 anyone else...... what if it was rebuilt maybe then welded on both sides Quote Link to comment Share on other sites More sharing options...
CFH87 Posted July 23, 2011 Report Share Posted July 23, 2011 Redline racing does it just seen on their web sight. Quote Link to comment Share on other sites More sharing options...
shakar Posted July 24, 2011 Author Report Share Posted July 24, 2011 great thanks for the info Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted July 25, 2011 Report Share Posted July 25, 2011 Every crank I have seen, all of them have come from JD Racing or Twister, have been welded on the center pin and the rod pins!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
uk421Shee Posted July 26, 2011 Report Share Posted July 26, 2011 Why do people weld the cranks up? Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted July 26, 2011 Report Share Posted July 26, 2011 So they don't separate. The crank webs, and pins are splined, so it's just pressed together. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted July 26, 2011 Report Share Posted July 26, 2011 They aren't even splined, just press fit. They are welded to keep from twisting and going out of phase. Also keep from seperating. Quote Link to comment Share on other sites More sharing options...
