4millshee Posted July 21, 2011 Report Posted July 21, 2011 2006 Banshee The motor has 5 minutes run time. New Wiseco crank and pistons, all new orings and gaskets. Motor starts 1st kick. I put it all together, started it, let it warm up and shifted through all 6 gears and shut it down. The motor still needs to be broken in, I am leaving the motor not broken in for the buyer to do it in what way they want it done. Its a California bike, the reason i am selling is because i want another honda 450 for the simplicity of having 2 of the same bike. If you would like and are serious about buying i will pull the head off (its an oring head so no new gaskets needed) to show that the internals are still brand new and im not BS'ing about the rebuild. Contact me by email or call/text 760-408-9817. Toomey T-5 Exhaust Bored to 65mm (stock is 64) Boyseen Reeds and Cages w/ Reed Sapcers Keihin PWK 35mm Carbs Dune Port Hinson Clutch Basket NOSS Cool Head 20cc Domes Adjustable Stator Plate Polished Clutch Cover w/ Insert Billet Water Pump Cover Dura-Blue 2-4 Axle Armadillo Bumper Pro Taper Bars Quote
