RC418 Posted July 12, 2011 Report Share Posted July 12, 2011 Has anyone had a problem with their clutch adjustment arm hitting the nut on the bottom of the carbeurator bowl? I have 34MM PJ's with UPP intakes and the clutch adjustment arm is hitting the nut on the bottom of the bowl, what have you done to fix this problem? I may try to file the nut down a bit to see if I can gain enough clearance but i'd like to see what others are doing first. Thanks Quote Link to comment Share on other sites More sharing options...
Sandking Posted July 12, 2011 Report Share Posted July 12, 2011 Just bend the arm down a little. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted July 12, 2011 Report Share Posted July 12, 2011 Three options: 1) Find some angled intakes and hope that works 2) File that nut down 3) Get reed spacers to move the carbs back I think the spacers would probably work the best. Quote Link to comment Share on other sites More sharing options...
Ingram306 Posted July 12, 2011 Report Share Posted July 12, 2011 My PWKs hit the arm, just bent it down a litle bit.. few light taps with a hammer, didnt give me too much trouble and hasnt effected my clutch operation Quote Link to comment Share on other sites More sharing options...
