Screw 4 strokes Posted June 16, 2011 Report Posted June 16, 2011 Would lrd rfx pipes work well with my current set up. It is in my signature and i also have +4 timing, Thanks. Quote
06specialedition Posted June 16, 2011 Report Posted June 16, 2011 Would lrd rfx pipes work well with my current set up. It is in my signature and i also have +4 timing, Thanks. Kevin @ HJR would probably be able to tell what would be best with your porting. If you dune alot I would run CPI or Shearer IMO Quote
Screw 4 strokes Posted June 16, 2011 Author Report Posted June 16, 2011 All i do is ride dunes, but i jump a lot at Pismo. so i would still like some low to mid grunt and i want a pipe that isnt gonna melt my boot every time i jump. Quote
SandSlingerOR Posted June 18, 2011 Report Posted June 18, 2011 I would look into pro circuits; I really like them. I have 20cc domes , +3 timing , 28mm carbs , boyseen reeds and pro circuits pipes. I have no port work and I couldn't be happier with the low end my banshee produces. Quote
nastyracing Posted June 23, 2011 Report Posted June 23, 2011 Lrd adjustable pipes 28 mm pwk carbs is exactly the set up you are looking for still have hard pulling top end but rideable jumpable power I'm a mx guy and that's the set up I run on my banshee although race 450 on mx track . That's the closest set up you gonna get to a torqy jumping machine. Quote
camatv Posted June 23, 2011 Report Posted June 23, 2011 pro circuits will out pull a lrd on the bottom. the lrd will have a lil more pipey hit to it they come on stronger and more abrupt in the upper rpm range. that makes mx jumping a lil more difficult yuo have to time the pipe hit exactiully with the jump or risk some issues on the jump.. if you want to clear your boots the best your real only choice is a set of paul turner high rev stay away from the low end or midrange pipes. Quote
