screamin_mimi Posted June 15, 2011 Report Posted June 15, 2011 Does anyone know if the connector pipe between the carbs is necessary? has anyone ever removed it?? What are the pro's & con's?? Thanks!!! Quote
dcalsv02 Posted June 15, 2011 Report Posted June 15, 2011 That tube is 100% necessary. That is the choke tube. Quote
dcalsv02 Posted June 15, 2011 Report Posted June 15, 2011 Or are you talking about the crossover tube? The aluminum u shaped pipe or the small straight rubber tube? Quote
screamin_mimi Posted June 15, 2011 Author Report Posted June 15, 2011 Or are you talking about the crossover tube? The aluminum u shaped pipe or the small straight rubber tube? Tha aluminum u shaped pipe ... Quote
dcalsv02 Posted June 16, 2011 Report Posted June 16, 2011 I believe you either, have to have one or block the holes in the boots off. Im pretty sure they make after market boots that are already plugged. Quote
Larry's Shee Posted June 16, 2011 Report Posted June 16, 2011 I used 1/2" pvc caps with threebond and clamps to delete boost bottle because of cracks. Quote
