I'm building a 421 cub and wanting to know can I use my head and domes from my existing 66mm x 58mm stock cylinder motor.. im using the hotrods long rod crank..standard 68mm pistons not the blaster angle..forgot to mentioned I have P Powerheads w/19cc domes.. also have unopened 21cc dome that I can use also.. thanks!!!
Get 68mm domes cut for your application.
ok..who would you recommend...or can a stock head be modded for the application.....sorry for all the ?s its my first cub build...
Stock head can be modified. But a coolhead setup will allow you to change domes easily. I'd recommend NOSS, or any of hte site sponsor builders if you want to talk to a builder about specific dome configurations.
You need domes for blaster pistons,Im almost 100% positve you cant rechamber a banshee dome for a blaster piston due to the angle of the piston crown,FAST can hook you up for sure but that PT head might limit you on places to buy from
so do I have to use blaster pistons with the long rod cub build or can I use a regular wisco 68mm piston?
