03banshee20 Posted June 3, 2011 Report Posted June 3, 2011 can someone get me picsof the right side main bering mine looks like the little pin sheared off and the bering moved and the pin piece went up in the motor and tore my head and piston up. but im not sure. also what do i have too do to change crank berings thanks Quote
bansheesandrider Posted June 3, 2011 Report Posted June 3, 2011 can someone get me picsof the right side main bering mine looks like the little pin sheared off and the bering moved and the pin piece went up in the motor and tore my head and piston up. but im not sure. also what do i have too do to change crank berings thanks If your bearing is bad, I would send the whole crank to be rebuilt. I would not take a chance on the other bearings- you don't know how wore they are or how much shrapnel has gone through them. If it is an outer bearing, you can just pull it off the crank and press on a new one aftyer splitting the cases to get the crank out. Twister should be able to rebuild it and true and weld it for around $350 plus shipping and they do great work. Quote
