.006 ring gap. I was thinkin 5 maybe 10. Better hold off on droppin my dome size
dont be disappointed if it doesnt change much though. the last few engines ive done havent had a drastic change.
I don´t know much about what you are asking, but have you measured your squish with your new topend?
I did my topend and it was 115 and 110psi before, and after a new topend it was 135 in both cyls. I was expecting something closer to 155 to 160 because my did the head milling at the same time.
The problem was a little too thick base gasket and my squish was 1.65mm!
-Pasi S.
-Pasi S.
which base gaskets did you use?
I don´t remember the brand, but def not a Cometic. They came with the top end-kit. the base gasket was 1mm thick.
Now I have 0.5mm Cometic steel gaskets.
-Pasi S.
.006 seems real tight if you already ran it you should be fine I think it is suppose to be closer to .01 or .012
