Codemilr Posted May 26, 2011 Report Share Posted May 26, 2011 (edited) I have a 2001 Banshee. It will start and run but when i open it up it only bogs and doesnt pick up speed. It will rev up fine if i pull the clutch in. What wrong...Thanks for any help. Edited May 26, 2011 by Codemilr Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 26, 2011 Report Share Posted May 26, 2011 Welcome!! Did it start running bad all of a sudden? Something that got progressively worse? Did you change ANYTHING dealing with intake or exhaust? More info is needed. Alist of modifications might also be helpful. Quote Link to comment Share on other sites More sharing options...
Codemilr Posted May 26, 2011 Author Report Share Posted May 26, 2011 Welcome!! Did it start running bad all of a sudden? Something that got progressively worse? Did you change ANYTHING dealing with intake or exhaust? More info is needed. Alist of modifications might also be helpful. It has been completely rebuilt and has toomey t6 exhaust, a K&N Filter, and the timing has been advanced. Just got it running yesterday and it will not even start to open up. Could it be in the jetting im not sure if the guy i bought it from rejetted it for the exhaust and filter. Thanks Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 26, 2011 Report Share Posted May 26, 2011 Did you clean carbs while it was apart? Are slides in correct carb? Cutaway faces air box. Float bowls on correct carb? One with "BB" goes on left carb. Choke crossove tube on? TORS or parking brake shit still hooked up? =problems. List your carb jetting/settings. Quote Link to comment Share on other sites More sharing options...
pweezy42 Posted May 26, 2011 Report Share Posted May 26, 2011 i think larry hit it in the head it sounds like crossover tube or slides in backwards, im saying this cause ive done both b4 Quote Link to comment Share on other sites More sharing options...
Codemilr Posted May 26, 2011 Author Report Share Posted May 26, 2011 Thanks for the info i will try checking all of those and i will let you know what happens...Thanks I believe that the jetting is stock and the guy that had it before me didnt rejet it for the exhaust and fiter. What size jets would u recommend for this setup Quote Link to comment Share on other sites More sharing options...
Codemilr Posted May 27, 2011 Author Report Share Posted May 27, 2011 Checked all of the hoses and it runs a little better but still wont open up...Thanks for any help Quote Link to comment Share on other sites More sharing options...
malcman Posted May 27, 2011 Report Share Posted May 27, 2011 Check your jetting size for sure Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 27, 2011 Report Share Posted May 27, 2011 Check the sticky "What jets are you running" inthe jetting forum, see if you can find a simular set-up and go from there. Pull the main and pilot in one carb and see what they are and post up. I would guess 250-260 at least, 200 is stock main. Might want to try 27.5 pilot. Quote Link to comment Share on other sites More sharing options...
