Codemilr
Everything posted by Codemilr
  1. Thanks for all the input....i will be back in the shop wednesday after school....i have decent fabrication and wiring skills...and i have a fuel injected 98 camaro z28 with a ls1 383 stroker, i dont know if it is anything like a gsxrs but it is fuel injected...i will post pictures after i get the motor mounted...thanks
  2. Thanks for the help...The reason im swapping to the bike motor is that there is something wrong with the banshee motor and i have tore the motor apart and still cant find what is wrong...and i got a really good deal on this bike motor....Thanks
  3. I guess this could be called a mod....I have a 2001 Banshee and a 05 GSXR 600 engine...i have already got the frame cut and the motor s about to be mounted...i couldnt find a way to run the exhaust...Any suggestions?....Thanks
  4. i have pulled the carbs out an cleaned them a few times...i will check the reeds probably 2day or 2morrow...Thanks
  5. I was wondering if the reeds could cause my banshee to bog and not speed up...it wont even lauch like a banshee should...to give you an idea of how bad it is running, my grandpas 50cc moped (Governed at 35mph) was about to stay with me on it...Thanks for any help
  6. Checked all of the hoses and it runs a little better but still wont open up...Thanks for any help
  7. Thanks for the info i will try checking all of those and i will let you know what happens...Thanks I believe that the jetting is stock and the guy that had it before me didnt rejet it for the exhaust and fiter. What size jets would u recommend for this setup
  8. It has been completely rebuilt and has toomey t6 exhaust, a K&N Filter, and the timing has been advanced. Just got it running yesterday and it will not even start to open up. Could it be in the jetting im not sure if the guy i bought it from rejetted it for the exhaust and filter. Thanks
  9. I have a 2001 Banshee. It will start and run but when i open it up it only bogs and doesnt pick up speed. It will rev up fine if i pull the clutch in. What wrong...Thanks for any help.
