pumarat Posted May 18, 2011 Report Posted May 18, 2011 Need some help, just bought a set of mx-dune ported stock cylinders with 68mm la-sleeve big bore done by herrs racing so I'm told. The person I bought them from claimed 87hp on alchol? I'm running a stock crank with timing plate, flywheel, 35mm, t-5s and I was wondering what kind of pistons to run? Can I run the wiesco 68mm cub pistons? And also I'm planning to run 110 octane so what would be the best domes to run with this set-up? Is this set-up comparable to running a stock stroke cub? New to this engine building and any help would be appreciated. Quote
shanYE west Posted May 18, 2011 Report Posted May 18, 2011 Need some help, just bought a set of mx-dune ported stock cylinders with 68mm la-sleeve big bore done by herrs racing so I'm told. The person I bought them from claimed 87hp on alchol? I'm running a stock crank with timing plate, flywheel, 35mm, t-5s and I was wondering what kind of pistons to run? Can I run the wiesco 68mm cub pistons? And also I'm planning to run 110 octane so what would be the best domes to run with this set-up? Is this set-up comparable to running a stock stroke cub? New to this engine building and any help would be appreciated. I dont think you can run blaster pistons unless your using a long rod crank.. at 68mm your either going to have to use a trinity piston or WSM. Quote
BigRed350x Posted May 18, 2011 Report Posted May 18, 2011 If kevin did the work, give him a call and he can answer your questions for you... If he did the work, he will have a record of the cylinders and can hook you up with what will and won't work. - Jared Quote
pumarat Posted May 18, 2011 Author Report Posted May 18, 2011 yea I was planning on calling him, I just didn't know if he would have a record of the cylinders or not. Thx Quote
CFH87 Posted May 18, 2011 Report Posted May 18, 2011 Compression and domes for race gas depends on elevation and I would definitely give Kevin a call. Quote
