Joey80 Posted May 18, 2011 Report Posted May 18, 2011 Ok, I have a 1990 Yamaha Banshee. The bike was just recently put back together. I found out my coil was bad so I borrowed one from a friend. The bike ran so I took it out for a quick run. The bike ran great until 4th gear when it shut off on me. I am currently running 270 main jet at 4200 altitude. When I got the bike back to my house I had no spark at all. Can anyone help to point me in the right direction? Thanks in advance for any help. Quote
Boston Posted May 18, 2011 Report Posted May 18, 2011 id check out your stator. maybe your flywheel nut came off? Quote
Joey80 Posted May 18, 2011 Author Report Posted May 18, 2011 I had the flywheel nut come off last time...I did check that but its still all together. What tests can I do to check the stator? Quote
Boston Posted May 19, 2011 Report Posted May 19, 2011 to be honest i dont know how to test the stator but you do some searching on here theres plenty of how to topics on this one. Quote
Rotax Raptor Posted May 19, 2011 Report Posted May 19, 2011 Unplug your stator and using an ohm meter test resistance between the white/red and the white/green wire. It should read around 117 ohms if good. I think that's the right number, I'll verify and repost. I've also seen the pickup coil gap to wide and cause this. Quote
