RobertR Posted June 13, 2011 Report Posted June 13, 2011 I have a 4mil 421 serval and I like it makes good power and nice tq and no its not a drag motor nor will it be and the cost is not that much if you all ready have some of the bolt ons. But if your going to drag then by a cub. Quote
Paulie B Posted June 24, 2011 Report Posted June 24, 2011 lets get together adn then you can ride my 421 stock cylinder "trail bike" How much did it cost you to build this motor vs just buying a serval? Quote
camatv Posted June 24, 2011 Report Posted June 24, 2011 depends on what you would already have the bottom ends are built the same at least how i do it.. the only real differnce is the cost of the sleeve's and installing them and the cylinder porting.. so really the cost is nearly the same the power delivery is very similar from the serval ( with proper pipes and dome selection) to a well built 421 stocker. is guess sleeve's and install would probably be around 350-400 bucks. then a good port after the sleeve i'd guess around 300-450 ish so about 850 and thats not much diff in price from a serval.. BUT if your a machine shop then all it is is time and the cost of the sleeve Quote
Paulie B Posted June 26, 2011 Report Posted June 26, 2011 depends on what you would already have the bottom ends are built the same at least how i do it.. the only real differnce is the cost of the sleeve's and installing them and the cylinder porting.. so really the cost is nearly the same the power delivery is very similar from the serval ( with proper pipes and dome selection) to a well built 421 stocker. is guess sleeve's and install would probably be around 350-400 bucks. then a good port after the sleeve i'd guess around 300-450 ish so about 850 and thats not much diff in price from a serval.. BUT if your a machine shop then all it is is time and the cost of the sleeve would my trail ported 66mm jugs work or would I also have to buy unported stock cylinders? Quote
camatv Posted June 26, 2011 Report Posted June 26, 2011 sleeving is best to do with some cylinders that the sleeves are trashed in 66's would be a good canidate. Quote
