bigblockbanshee Posted May 3, 2011 Report Posted May 3, 2011 I've got 1-1/8" Pro Taper Contours right now with just your regular billet adapter/risers. What I wanna do is keep the bottom half of my risers and find a top half that will bolt right up to the bottom part that also has a key hole for the switch, nothing too fancy. The bolt spread on my risers is approximately 90mm center-to-center across and 41.5mm center-to-center vertically. Right now I have my switch zip tied to my front brake line and it looks extremely tacky but I have no choice at the moment. Am I looking for something that doesn't exist here or what? Quote
ban99 Posted May 3, 2011 Report Posted May 3, 2011 (edited) I think you would be better off to do away with the key all together or re-locate it under the seat. If you are determined to incorporate it into the riser I would get with JD from JDS customs and have him make you up something. http://www.jdscustoms.com/ Edited May 3, 2011 by ban99 Quote
bigblockbanshee Posted May 4, 2011 Author Report Posted May 4, 2011 How do I eliminate the switch? Quote
