ionroller Posted April 26, 2011 Report Posted April 26, 2011 I have 30 mm OKO carbs on my banshee, mods in sig. I think my main is 168 now. I had a hesitation before the power band, I put the lid on to rule out being lean, and it runs better now. how many sizes up should I go to be safe with the air lid off? Quote
Wildcardracing Posted April 26, 2011 Report Posted April 26, 2011 I'd go up at least two sizes and continue tuning. But a stumble before the powerband is likely a midrange jetting issue, I'd also recommend raising your needle one clip position. Quote
ionroller Posted April 26, 2011 Author Report Posted April 26, 2011 so lean the needle also. I plan to get JJH needles, should I still go middle clip? Quote
Wildcardracing Posted April 26, 2011 Report Posted April 26, 2011 No, you want to raise/richen your needle. Post up your complete setup and current jetting, we will be better able to help you out with it. -Brandon Quote
ionroller Posted April 27, 2011 Author Report Posted April 27, 2011 Stock Stroke HJR Dune port +4 Timing Chariot Reed cage Boysen power reeds Foam Uni filter Open Air box Mull Head 150 Psi 32:1 Ams oil interceotor 30mm OKO carbs 165 Main 50 pilot Quote
sleeper06 Posted April 28, 2011 Report Posted April 28, 2011 165 is a big jet for those carbs,i suggest you do a plug chop and dial in your main first,then move to the needle which is where i think your problem is Quote
ionroller Posted April 29, 2011 Author Report Posted April 29, 2011 i looked at my plugs after i rode pretty balls out to a friend house, about 2 miles. I pulled in and looked at my plugs and they looked lean. It was running like shit too. Put my air bow lid on and it runs better? I figured I would be at like 155? Quote
ionroller Posted May 3, 2011 Author Report Posted May 3, 2011 lowered my needle 1 clip and it runs great now.. I double checked and my mains are a 165. Quote
