Okay so I have a set of reed cages that I'm not sure what they are, I thought they were stock at first glance but realized they're slightly larger and have three screws per side rather than two. They don't appear to be an aftermarket piece, more like a factory take off from something else?
Here are the pics.
Thank you for the link Pasi.
According to the diagrams in the link it has the same dimensions as the banshee cage except the windows are slightly larger. The windows are 22.5 mm wide and 28 mm tall making it .5 mm larger in both dimensions.
Here you can see the difference in the reed pedals.
Thanks for the info Screamin, I'll see what I can find out about the fmf cages.
Any of you guys run any of these?I have a set and was thinking of running them. How do they compare to carbon fiber stock cage reeds? Thanks
