Need help got my banshee out of storade and i elimated the air box and put 2 pod filters on when riding it i cant run full throttle but still hav a strong powerband until i hit 5th gear and while ridding i noticed white smoke then no smoke then white smoke i also adjusted the air screwsan no luck... also banshee is completly stock to thanks!!
Did you jet your mains up for getting rid of the air box?
no i didnt... i was hopin i could work around that with the air screws but what would you recomend??
If you went from having an airbox to pod filters I would go up atleast 4-5 sizes on your mains. Then you cant work your way up or down from there. Any mods that increase air flow....need more fuel.
i agree with 06.ur definately too lean.i gotta ask,if its all stock,y did u put pods on it???air screws only adjust air/fuel from idle to 1/4 throttle.1/4 to 3/4 is needles and clip position,and 3/4 to wfo is main jet.check out the sticky.
