hi ive recently think about buying big bore cylinders and sell my pistons wiseco 795, my stroker crank and my ported cylinders who are too much ported for me . I will buy the 392cc athena big bore cylinders kit with pistons but i also want a stroker crank to make it 421cc i want to sell my old stroker because its also long rod and i would need to change the new pistons..
so let me know what you think about this. i have a couple of questions to ask too.
link: http://cgi.ebay.com/ebaymotors/YAMAHA-350-BANSHEE-ATHENA-392CC-BIG-BORE-CYLINDER-KIT-_W0QQcmdZViewItemQQhashZitem3366daba91QQitemZ220768942737QQptZMotorsQ5fATVQ5fPartsQ5fAccessories
1. what is the role of a +5mm long rod?
2.does stock ported cylinders are much powerfull than non ported big bore cylinders?
3.what is the difference between PWK and air strikers Keihin carbs?
4.what is a serval cub?
5.should i keep my coolhead with this kit or the head that comes with will be similar?
6. if the cylinders grips, will i just need to change the sleeves?
ps. my mods:
-CPI small bore inframe pipes
-barnett clutch
-35mm PWK Kehin carbs
-cool head prodesign
-stroker +4mill crank
thank you.
