jonvia Posted April 12, 2011 Report Posted April 12, 2011 to clean my carbs, i would take them off and spray inside and outside of it with carb cleaner? along with taking the bowl apart and spraying it also>? Quote
98MonsterShee Posted April 12, 2011 Report Posted April 12, 2011 Correct, take them apart pref. One at a time each carb is diff, spray the hell outta them n put back together real easy Quote
jonvia Posted April 12, 2011 Author Report Posted April 12, 2011 Correct, take them apart pref. One at a time each carb is diff, spray the hell outta them n put back together real easy yeah thats what i figured lol. what do you mean each one is different? lol Quote
rdzbangshee Posted April 12, 2011 Report Posted April 12, 2011 yeah thats what i figured lol. what do you mean each one is different? lol yep if you mix the fuel bowels up it will spill fuel all over the ground. Quote
jonvia Posted April 12, 2011 Author Report Posted April 12, 2011 yep if you mix the fuel bowels up it will spill fuel all over the ground. oh so use the same bowl off of the same carb? and put it back together the same? Quote
98MonsterShee Posted April 12, 2011 Report Posted April 12, 2011 Yea bro if it's ur first time takin them apart I recommend doing one at a time just so u dnt confuse anything Quote
jonvia Posted April 12, 2011 Author Report Posted April 12, 2011 Yea bro if it's ur first time takin them apart I recommend doing one at a time just so u dnt confuse anything yeah man that deff makes sense.thanks for the help guys! Quote
Larry's Shee Posted April 20, 2011 Report Posted April 20, 2011 The difference in bowls is the circut for choke. It won't spill fuel, your choke won't work !! If carbs are really bad get a 1gal bucket of Breeymans. Has a little strainer for parts in it, sweet!! Remove any plastic or rubber first. Quote
