hi I have a stroker +4 and i will buy a port job and 33-35 mm carbs, i do long straight lines and i like to ride like 1 or 2 hour in a row.. my question is should i get t5 for like 300$ or cpi's for 500$ and what are the big difference between these two pipes. i know that cpi pull later on rpm and t5 is an all around pipe but is that cpi have a similar pull than the others aftermarket pipes on a stock motor?? and what is the difference between 33 and 35mm carbs? thank you. :notworthy:
