seabass Posted April 9, 2011 Report Posted April 9, 2011 I have a gusset kit from Tarantula Racing. The upper rear chassis piece says (without airbox) under it in the instructions. I assume I don't use this piece if I'm running an airbox? It sounds like a dumb question but would like to be sure because it doesn't seem like it would be in the way with the airbox. All I have with me at my house is the frame and gussets so I can't check airbox clearance and I'm bringing it to the welder today. I would GREATLY appreciate it if anybody has any info on this. Thanks in advance. Quote
BigRed350x Posted April 12, 2011 Report Posted April 12, 2011 I usually make my own gussets. I've never seen the kit you're using. Post up some pics and we'll see if we can help ya out. - Jared Quote
Judge1 Posted April 12, 2011 Report Posted April 12, 2011 I have the kit on my biike. The piece you are talking about I moved farther to the back of the subframe. I run an air box with no lid and you could probably make it work by notching the air box. I just moved the gusset to behind the seat mount bracket just make sure it does not interfere with your grab bar mount holes! Quote
seabass Posted April 13, 2011 Author Report Posted April 13, 2011 I have the kit on my biike. The piece you are talking about I moved farther to the back of the subframe. I run an air box with no lid and you could probably make it work by notching the air box. I just moved the gusset to behind the seat mount bracket just make sure it does not interfere with your grab bar mount holes! Thanks alot. Just the info. I was looking for. I appreciate it. Thanks to all that took time to view my post. Quote
