jonvia Posted April 8, 2011 Report Posted April 8, 2011 is there a DIY on a compression test? i wana do one just to check.how do you do it? Quote
Burt Reynolds Posted April 8, 2011 Report Posted April 8, 2011 is there a DIY on a compression test? i wana do one just to check.how do you do it? Buy a cheap autozone tester. Remove one plug and screw the tester in,only hand tighten it. Make sure you hold the throttle wide open,give it 10-15 good kicks,but i always kick until it wont go higher. On a stockish shee 135ish is stock 110 and up is ok. Cylinders should be withint 5 psi of eachother. Quote
jonvia Posted April 8, 2011 Author Report Posted April 8, 2011 Buy a cheap autozone tester. Remove one plug and screw the tester in,only hand tighten it. Make sure you hold the throttle wide open,give it 10-15 good kicks,but i always kick until it wont go higher. On a stockish shee 135ish is stock 110 and up is ok. Cylinders should be withint 5 psi of eachother. hmm i see lol. i will lol. how much are they? Quote
robert.b.west Posted April 8, 2011 Report Posted April 8, 2011 Also make sure your ignition is off. I just bought one for $24 Quote
Larry's Shee Posted April 8, 2011 Report Posted April 8, 2011 Autozone has them on loaner program. Quote
bansheesandrider Posted April 8, 2011 Report Posted April 8, 2011 Buy a cheap autozone tester. Remove one plug and screw the tester in,only hand tighten it. Make sure you hold the throttle wide open,give it 10-15 good kicks,but i always kick until it wont go higher. On a stockish shee 135ish is stock 110 and up is ok. Cylinders should be withint 5 psi of eachother. WRONG- get a GOOD tester, remove BOTH plugs and kick it till tne needle quits climbing with the throttle wide open. That is how they teach you to do it in mechanics school, at least it was 25 years ago when I went. You also want to make sure the tester has the check valve right at the end of the fitting that screws into the head, as that can affect the reading also. Quote
NetBSD Posted April 8, 2011 Report Posted April 8, 2011 i picked up a cheapo at harbor freight for $9.99 a few days ago. but remember you get what you pay for, i got the cheapo one for in my trucks tool box and kept the good one in the garage Quote
jonvia Posted April 8, 2011 Author Report Posted April 8, 2011 WRONG- get a GOOD tester, remove BOTH plugs and kick it till tne needle quits climbing with the throttle wide open. That is how they teach you to do it in mechanics school, at least it was 25 years ago when I went. You also want to make sure the tester has the check valve right at the end of the fitting that screws into the head, as that can affect the reading also. what do you mean about the needle quits climbing? lol. help me out man Quote
jonvia Posted April 8, 2011 Author Report Posted April 8, 2011 http://cgi.ebay.com/ebaymotors/New-Gas-Engine-Compression-Tester-Testing-Gauge-Kit-NR-_W0QQcmdZViewItemQQhashZitem53e7057255QQitemZ360358179413QQptZMotorsQ5fAutomotiveQ5fTools would something like that be pretty decent? Quote
NetBSD Posted April 8, 2011 Report Posted April 8, 2011 what do you mean about the needle quits climbing? lol. help me out man kick yer brains out untill the needle stops climbing on the gauge Quote
jonvia Posted April 9, 2011 Author Report Posted April 9, 2011 kick yer brains out untill the needle stops climbing on the gauge oh! lol i see what you are saying lol Quote
