jonvia Posted April 8, 2011 Report Posted April 8, 2011 today i was riding, and my radiator started dripping onto my right exhaust pipe. is that a problem? just a busted hose? Quote
jonvia Posted April 8, 2011 Author Report Posted April 8, 2011 yes,a coolant leak is a problem. i figured it was... lol.i need to check asap! idt my radiator is getting enough airflow. and the hose prolly has a small hole Quote
sstaton1983 Posted April 8, 2011 Report Posted April 8, 2011 my guess would be loose rad. clamp. Quote
jonvia Posted April 8, 2011 Author Report Posted April 8, 2011 my guess would be loose rad. clamp. hmm prolly. should i get an oversized radiator? will it help with performance? Quote
sstaton1983 Posted April 8, 2011 Report Posted April 8, 2011 they have better cooling. they dont add performance they are just a supporting mod for a "built"motor.if you are mostly stock the stock one will be fine. EDIT::unless you are in the dessert. Quote
jonvia Posted April 8, 2011 Author Report Posted April 8, 2011 they have better cooling. they dont add performance they are just a supporting mod for a "built"motor.if you are mostly stock the stock one will be fine. EDIT::unless you are in the dessert. well the fins on my radiator are pooped haha.not very good at all... might get one so i dont blow an engine bahaha Quote
Larry's Shee Posted April 8, 2011 Report Posted April 8, 2011 Might be PIA, but you can straighten the fins Quote
