banshee jump Posted April 5, 2011 Report Posted April 5, 2011 hi, could someone give me instructions on how to drain all the coolant system thnx?And could someone tell me if prestone antifreeze/coolant is gd coolant to use??? Quote
robert.b.west Posted April 5, 2011 Report Posted April 5, 2011 I remove the radadiator hose where it goes into the side of the engine on the right hand side and pop the rad cap. It will come gushing out. I use "the green stuff" any brand should work. Quote
banshee jump Posted April 5, 2011 Author Report Posted April 5, 2011 (edited) I remove the radadiator hose where it goes into the side of the engine on the right hand side and pop the rad cap. It will come gushing out. I use "the green stuff" any brand should work. thnk u , hey i was wondering i have a kn filter on should iremove the air box snorkel? ive tried to take of the lid but when i try it the engine lags should i only remove the snorkel??? (I ride in dusty conditions) Edited April 5, 2011 by banshee jump Quote
Larry's Shee Posted April 5, 2011 Report Posted April 5, 2011 (edited) Also pull 10mm plugs on side of cylinders to drain all. If you pull lid off you will have to change jetting. Even pulling snorkel will increase air to where you might have to change jetting. Edited April 5, 2011 by Larry's Shee Quote
