Banshee Rider239 Posted April 5, 2011 Report Posted April 5, 2011 http://www.bansheedepot.com/proddetail.asp?prod=22%2D5730&cat=54 Quote
Larry's Shee Posted April 5, 2011 Report Posted April 5, 2011 Might try to be more specific on what you are trying to do. I can think of about 7 ways to adjust/tune it. Quote
Banshee Rider239 Posted April 5, 2011 Author Report Posted April 5, 2011 Might try to be more specific on what you are trying to do. I can think of about 7 ways to adjust/tune it. what does the fillip strew driver part do adjust higher or lower idle and if i was to turn it in or out wat affect does it make ? Quote
sstaton1983 Posted April 5, 2011 Report Posted April 5, 2011 wow!!,i think you are talking about the air mix screw you can run it in or out to fine tune the air fuel mixture.from your post i think you might be in over your head.if you dont know how to to tune a carb. you can lean out your motor and have a meltdown.i sugest you find a friend with some experience to help you out.meanwhile search and study so you can do it yourself next time. Quote
gotta_goatsfast Posted April 5, 2011 Report Posted April 5, 2011 sstaton has a point. Although everyone has to start somewhere, I suggest that if you are serious about carbs then look into a Keihin PWK series carburetor. IMO they are a lot easier to tune and there is a ton of support on here if you get into a bind. Having friends to show you first hand helps, too... Quote
Banshee Rider239 Posted April 5, 2011 Author Report Posted April 5, 2011 wow!!,i think you are talking about the air mix screw you can run it in or out to fine tune the air fuel mixture.from your post i think you might be in over your head.if you dont know how to to tune a carb. you can lean out your motor and have a meltdown.i sugest you find a friend with some experience to help you out.meanwhile search and study so you can do it yourself next time. mechanics around my area are very high im not a cheap guy but its not like these things take a rocket scientist i have learned alot while rebuildin this shee so im pretty sure with a little help from you guys i can have it runnin with no problem ....the problems im having are minor it could be resolve with a few notes and tips and suggestions from others ....i have gotten this far might as well keep goin so far alot of information i have heard has helped me well and ive learned a few things dat a few beginners just dont know off hand but im eager to learn more so help me out Quote
sstaton1983 Posted April 6, 2011 Report Posted April 6, 2011 (edited) ok, list all mods on bike,compression? what pipes? type of reeds. airbox or pods? list elevation and temp. in your area. EDIT: people are gonna say somthing about you posting in the wrong section. Edited April 6, 2011 by sstaton1983 Quote
Banshee Rider239 Posted April 6, 2011 Author Report Posted April 6, 2011 ok, list all mods on bike,compression? what pipes? type of reeds. airbox or pods? list elevation and temp. in your area. EDIT: people are gonna say somthing about you posting in the wrong section. bored the next step from stock, exaughst DMC 916's , good strong compression compared to kick (not tested yet), stock reeds , single air filters , temp 70-85 degrees weekly, elevation 231.4 ft Quote
gotta_goatsfast Posted April 6, 2011 Report Posted April 6, 2011 Carbs won't net you any gains. Consider the TORS removal kit for your stockers and invest in some reeds and advance the timing. Then get yourself a coolhead and up the compression a little. After that, port the bitch. THEN, you can consider carburetors as a worthwhile investment. Quote
sstaton1983 Posted April 6, 2011 Report Posted April 6, 2011 you are overcarbed.with that setup you still have plenty left with the stockers.you will not be happy with big. carbs on a stock port/stroke motor.the smaller carbs have a quicker throttle response.just keep the stock ones tuned and you will be happy. Quote
Banshee Rider239 Posted April 6, 2011 Author Report Posted April 6, 2011 ok thanks guys back to stock i go Quote
Larry's Shee Posted April 6, 2011 Report Posted April 6, 2011 (edited) Sudco has a good book on carb tuning. The Clymers manual covers the carbs very good. Nothing wrong with stock carbs, Isee a lot of builds with them. might look into getting them bored to 28mm. Remove tors properly. Edited April 6, 2011 by Larry's Shee Quote
Banshee Rider239 Posted April 7, 2011 Author Report Posted April 7, 2011 Sudco has a good book on carb tuning. The Clymers manual covers the carbs very good. Nothing wrong with stock carbs, Isee a lot of builds with them. might look into getting them bored to 28mm. Remove tors properly. Yeah I have Clymers manual coming through the mail hopefully it acknowledges me with what I need to know .... Tors ??? What are they I keep hearing it Quote
Larry's Shee Posted April 7, 2011 Report Posted April 7, 2011 Throttle Override Retarded Shit . Prevents runaway if throttle sticks, only problem is that they malfunction, when nothing is wrong. . Limits spark advance, sometimes limits it to no spark at all. Quote
Banshee Rider239 Posted April 7, 2011 Author Report Posted April 7, 2011 Throttle Override Retarded Shit . Prevents runaway if throttle sticks, only problem is that they malfunction, when nothing is wrong. . Limits spark advance, sometimes limits it to no spark at all. oh Quote
