4mill95 Posted April 3, 2011 Report Posted April 3, 2011 will this cable work for 34mm flat slides? http://www.rockymountainatvmc.com/productDetail.do?navType=type&vehicleId=1767&navTitle=Handlebars-Control&webTypeId=33&webCatId=12&prodFamilyId=14909 Quote
BigRed350x Posted April 4, 2011 Report Posted April 4, 2011 will this cable work for 34mm flat slides? http://www.rockymountainatvmc.com/productDetail.do?navType=type&vehicleId=1767&navTitle=Handlebars-Control&webTypeId=33&webCatId=12&prodFamilyId=14909 I'm not totally sure if the RMATV cable will give you enough throw to get the 34's open all the way and let them close all the way, but I can tell you that the thumb throttle cable that CascadeInnovations.net sells WILL work with your carbs. You might go over there and just pick one of their cables up. Quote
