muggzy Posted March 30, 2011 Report Posted March 30, 2011 OK, I went out and took a few pics of my stock foot peg and nerf mounting. I hadn't noticed it before, but apparently the kickstart is meant to hit the mounting tab of the stock foot peg. If you look at the kickstart pedal, there's a tab on there that makes contact with "ear" on the foot peg. I also took a side view so you can see where the pedal sits when mounted as far forward as it will go: Quote
dtr7720 Posted March 30, 2011 Author Report Posted March 30, 2011 OK, I went out and took a few pics of my stock foot peg and nerf mounting. I hadn't noticed it before, but apparently the kickstart is meant to hit the mounting tab of the stock foot peg. If you look at the kickstart pedal, there's a tab on there that makes contact with "ear" on the foot peg. I also took a side view so you can see where the pedal sits when mounted as far forward as it will go: alright, thanks man, ill just mess with the pilot jet then, il go look and see waht size it is Quote
