98MonsterShee Posted March 23, 2011 Report Share Posted March 23, 2011 to anyone who can help, this is my first banshee iv had it almost a full season now.......took it out yesterday first day this spring had a great day riding 2 hrs in it started to bog out when i gave it gas eventually it died, i let it sit thinking i flooded it. It started up 5 min later ran for a lil bit but kept dyin whenever i put it in gear to move, long story short i had to tow it back and im hopin to get this resolved so i can get back out there and rip thanks alot guys any comments or thoughts on the issue are appreciated Quote Link to comment Share on other sites More sharing options...
VooDooBanshee Posted March 23, 2011 Report Share Posted March 23, 2011 to anyone who can help, this is my first banshee iv had it almost a full season now.......took it out yesterday first day this spring had a great day riding 2 hrs in it started to bog out when i gave it gas eventually it died, i let it sit thinking i flooded it. It started up 5 min later ran for a lil bit but kept dyin whenever i put it in gear to move, long story short i had to tow it back and im hopin to get this resolved so i can get back out there and rip thanks alot guys any comments or thoughts on the issue are appreciated What mods are on it? Need to know that first. Take the carbs off and clean them well. Use compressed air to clean the passages and jets. Use a good amount of carb cleaner in each. Do you have spark - good spark? Your looking at a spark, fuel or air issue, but you need to do some testing to see which one - then go from there...First take the plug out and plug it in to the boot/wire. Ground it on the head and see what kind of spark you are getting. You should see a fat blue spark on each. Take both plugs out at the same time to ease kicking it over by hand. Is your air cleaner clean? Compression good on each jug? Quote Link to comment Share on other sites More sharing options...
98MonsterShee Posted March 23, 2011 Author Report Share Posted March 23, 2011 I just recently replaced the coil with a Ricky stator coil and changed plugs, I hav toomey t-5s on it and a k an n air filter Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 23, 2011 Report Share Posted March 23, 2011 What did the plugs look like? Quote Link to comment Share on other sites More sharing options...
98MonsterShee Posted March 23, 2011 Author Report Share Posted March 23, 2011 uhm they weren't the same as the stock ones but i mean i tested the spark at the time and it was minty, iv heard the aftermarket coils arent as good as the stock ones could that possibly be a reason its causin this problem? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 23, 2011 Report Share Posted March 23, 2011 If you still have old coil and its good, throw it back on and see if you have spark. As to plugs I was asking what color the old plugs you took out were. Quote Link to comment Share on other sites More sharing options...
98MonsterShee Posted March 23, 2011 Author Report Share Posted March 23, 2011 Nah the old coil went on me but the old plugs were white Quote Link to comment Share on other sites More sharing options...
98MonsterShee Posted March 23, 2011 Author Report Share Posted March 23, 2011 Haha yea man half a tank, first thing I checked....iv made enough dumb mistakes Quote Link to comment Share on other sites More sharing options...
VooDooBanshee Posted March 23, 2011 Report Share Posted March 23, 2011 There are screws on the bottom of the bowls. Unscrew them and see if fuel comes out of each one. You need to make sure you are getting proper air, fuel and spark. That's really all there is to the banshee. The CDI and coil seldom fail, however there are other issues like failed stator, sheered off woodruff key and loose fly wheel that can cause spark/starting issues. Is it backfiring at all? Quote Link to comment Share on other sites More sharing options...
98MonsterShee Posted March 23, 2011 Author Report Share Posted March 23, 2011 No it hadn't been at all Quote Link to comment Share on other sites More sharing options...
VooDooBanshee Posted March 23, 2011 Report Share Posted March 23, 2011 No it hadn't been at all Do a compression test and post the numbers. Check spark and fuel as stated above. Will it start at all? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 23, 2011 Report Share Posted March 23, 2011 The clue is the color of the plugs. Only new plugs should be white. Either way lean jetting or major air leaks. JMHO, your results may vary. Quote Link to comment Share on other sites More sharing options...
