2stroke in my blood Posted March 22, 2011 Report Posted March 22, 2011 hi guys, im looking at converting my engine to power valved top end. i can get a nice set of jugs for under 100 bucks which i think is a bargain! i know i will need additional wiring etc, what else is needed? is the exhaust port for the pipes the same on the banshee and rz350? any help would be appreciated, thanks heath. Quote
SlowMoe Posted March 22, 2011 Report Posted March 22, 2011 hi guys, im looking at converting my engine to power valved top end. i can get a nice set of jugs for under 100 bucks which i think is a bargain! i know i will need additional wiring etc, what else is needed? is the exhaust port for the pipes the same on the banshee and rz350? any help would be appreciated, thanks heath. If it is a rz350 top end I believe the exhaust will hook up directly to the banshee exhaust. The rz exhaust port is around 200* fully open not sure what it is closed. You will need the servos for the poweravalves, and I'm not sure but I think you need an RZ350 wiring harness as well. So cylinders, powervalves, servos, harness. Not sure if the CDI and stuff is compatible Quote
2stroke in my blood Posted March 23, 2011 Author Report Posted March 23, 2011 If it is a rz350 top end I believe the exhaust will hook up directly to the banshee exhaust. The rz exhaust port is around 200* fully open not sure what it is closed. You will need the servos for the poweravalves, and I'm not sure but I think you need an RZ350 wiring harness as well. So cylinders, powervalves, servos, harness. Not sure if the CDI and stuff is compatible thanks for that. yeah i think i might need to run an rz350 cdi as well to activate the servos??? ive only just started looking into this so the more info i get the better Quote
RZBansheeMan Posted March 23, 2011 Report Posted March 23, 2011 PM member Meat. I think he said he still has a bunch of stuff from his RZ Banshee conversion that he was considering getting rid of, and if not I might get rid of some of my stuff. Mike Quote
Coupelx Posted March 23, 2011 Report Posted March 23, 2011 the banshee exhaust doesnt just hook up as they use a 2 bolt flange like the blaster and not all of the pipes clear the powervalves. you will also need all the electronics and servos for it. Quote
Burt Reynolds Posted March 23, 2011 Report Posted March 23, 2011 The rz350 electric is different. I remember i was looking to convert to rz350 electric but i needed the stator/cdi/ect,basicaly the whole deal so i decided not to do it. The older rocket pipes clear the rz cylinders i believe. Quote
