1998BansheeLover Posted March 14, 2011 Report Posted March 14, 2011 so pulled my banshee out of storage and went riding and eventually it got dark, and i turned the headlights on and they would work so i made sure everthing was plugged up and still wont work, before i put it in storage when i switched it on high only one would work but on low they both would, do i need new lights? Quote
n2otoofast4u Posted March 14, 2011 Report Posted March 14, 2011 Do you own a test light? If not, buy one.. You can figure this one out all on your own I bet!! Quote
Jereme6655 Posted March 15, 2011 Report Posted March 15, 2011 it sounds like you may need a new light......but i would also take apart the headlight switch and check the connections and check for corrosion inside of that. Could be starting to corrode and cause electrical issues Quote
bansheesandrider Posted March 15, 2011 Report Posted March 15, 2011 so pulled my banshee out of storage and went riding and eventually it got dark, and i turned the headlights on and they would work so i made sure everthing was plugged up and still wont work, before i put it in storage when i switched it on high only one would work but on low they both would, do i need new lights? If both headlights are burned out on both high and low beams, there is a good chance that your voltage regulator is BAD and is putting to much voltage to the bulbs and blowing them. Quote
