rajaa11 Posted February 26, 2011 Report Share Posted February 26, 2011 Hello all, I was wondering can I run the banshee with maybe 3 or 4 clutch springs? Reason I ask is because my clutch is really hard to pull in, I have check and did everything I could think of. I oil the cable, install stock spring, and torque them to spec, I even tried under torque to see maybe the springs were to tight. I have a stock clutch lever, so I been looking at the EZ pull clutch levers to see if this may help. Thanks Quote Link to comment Share on other sites More sharing options...
jasons Posted February 26, 2011 Report Share Posted February 26, 2011 Nice picture with no HELMET!!!! oh BTW i wouldnt recommend running no less then 6 springs. Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted February 26, 2011 Report Share Posted February 26, 2011 (edited) Negative, 6 springs always but you can 3 and 3, or 3 stock and 3 aftermarket. You could possibly run 2-2-2 which is 3 springs of different pressures alternated but I've never heard of it and I don't know how it would affect the assembly and/or the balance of it. Personally I'd stick with 3 and 3 unless you have some huge power. Are you sure your clutch itself is ok and not fried? Try lubing the cable as well, not with "oil". Edited February 26, 2011 by bigblockbanshee Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 27, 2011 Report Share Posted February 27, 2011 Check that the bearing where the arm goes into case isn't jacked. Try cleaning then lubericating cable. If that fails get a new cable. Quote Link to comment Share on other sites More sharing options...
