Larry's Shee Posted February 22, 2011 Report Posted February 22, 2011 Theroredically keeps from having a ruaway engine if the throttle sticks. Usually causes more problems than it's worth 99.999% remove or delete it. Quote
06specialedition Posted February 22, 2011 Report Posted February 22, 2011 What does it do? It could possibly cause issues if you leave it on. That would be one of the first things I would do is get the tors remove kit Quote
cpetersen Posted February 22, 2011 Author Report Posted February 22, 2011 It could possibly cause issues if you leave it on. That would be one of the first things I would do is get the tors remove kit My son in law had problems with his Blaster. It was running rich like the choke was on. I unhooked the TORS wires and it ran perfectly but would not idle. I hooked the wires back up and she now runs fine. I have no clue what happened? Quote
fastquad02blaster Posted February 24, 2011 Report Posted February 24, 2011 My son in law had problems with his Blaster. It was running rich like the choke was on. I unhooked the TORS wires and it ran perfectly but would not idle. I hooked the wires back up and she now runs fine. I have no clue what happened? Sounds like the switch on the carb or the switch on the throttle was giving you problems. Either way. If you properly delete the tors, you wont have to worry about it when your riding. Quote
