steeler2169 Posted February 20, 2011 Report Share Posted February 20, 2011 if the top end loses compression will it change your plug color?Or is there a differnt issue,such as crank seal.My plugs are black and wet but I know I need a top end because theres only 68psi. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 20, 2011 Report Share Posted February 20, 2011 You answered your own question and the longer you run it loose like that the more possibility of catastrophic failure,with compression that low i doubt a hone is possible you prob need to bore it Quote Link to comment Share on other sites More sharing options...
