Quick question for you guys. Could the float level (if set to high) cause it to be hard to start when the bike is cold. I have a fresh top end and the bike rips once I get it started. It takes anywhere from 7-12 kicks to get it fired up after that it fine. The last time I rode the bike I forget to shut the fuel off when I was done. When I went into the garage the next day I noticed that fuel was comming out of the right side carb.
Any thoughts?
Probably just sticking float. Might be time to clean them puppies out.
I just had them apart and cleaned everything out, but I didnt check the float level. If the flat is to high will it cause it to be hard to start?
