Complete transmission,shift forks,fork rails,shift drum,the little arm and spring that go against the drum,shift drum retainer,shift shaft,shift shaft adjuster post. I also have a complete clutch,inner/outer hub,pressure plate,clutch discs,pushrod,ball bearing,and pressure plate adjuster,and the actuator for 50$
100$ obo
  • 3 months later...
