Burt Reynolds Posted February 18, 2011 Report Posted February 18, 2011 Complete transmission,shift forks,fork rails,shift drum,the little arm and spring that go against the drum,shift drum retainer,shift shaft,shift shaft adjuster post. I also have a complete clutch,inner/outer hub,pressure plate,clutch discs,pushrod,ball bearing,and pressure plate adjuster,and the actuator for 50$ 100$ obo Quote
Strm Trpr Posted May 18, 2011 Report Posted May 18, 2011 (edited) You still have this? Edited May 18, 2011 by Strm Trpr Quote
