10milmike Posted February 17, 2011 Report Posted February 17, 2011 I have a quick question. Left side jug has no compression at all. Have not yet torn the motor apart about too.but I think is blown rings do u think I am right. Quote
Phelps Posted February 17, 2011 Report Posted February 17, 2011 0 compression is bad..... even if you took the rings out it would show something.... broke crank, broke rod, etc would show 0lbs Quote
10milmike Posted February 17, 2011 Author Report Posted February 17, 2011 0 compression is bad..... even if you took the rings out it would show something.... broke crank, broke rod, etc would show 0lbs I found the problem broke rings and a hole in the side of the piston. Already on it way to being fixed, thanks Quote
fastquad02blaster Posted February 17, 2011 Report Posted February 17, 2011 That sucks. Hope it all goes well for you on the rebuild. Quote
10milmike Posted February 17, 2011 Author Report Posted February 17, 2011 Its easy not my frist rebuild but thanks. Quote
10milmike Posted February 19, 2011 Author Report Posted February 19, 2011 Lol true I do all my friends this build is not even mine. Quote
