so i just got done trying to put my cool head on and failed thanks to the oring in my left dome falling out and getting pinched between the dome and the cylinder. unfortunately i didnt notice untill i was trying to fill my radiator with coolant and noticed the coolant flowing out of my left cylinder exhaust port. it looked like all of it was flowing out of the exhaust but im kinda worried some may have found a way down into my bottom end. my question is, should i be worried about it? is or could it be a big enough problem that i should split the cases and get whatever coolant that may be in there out?
If it were my bike i would just slowly rotate the motor around by hand to make sure its still rotating fine for peace of mind before i fired it. letting it sit in there shouldn't be an issue...it should disapate over time as you ride. If you REALLY want to know then you could actually just pull off your left side cylinder and use a flashlight and look down into your cases to see if you can see anything.....although i doubt you will find much at all.
