Tombola Posted February 12, 2011 Report Posted February 12, 2011 Hi all from across the pond! I have a 04 banshee, I done a compression test and I got 90 psi although the quad started first kick and went like the clappers. Today I installed new genuine piston rings, the bores looked fine still had the original cross hatchings. After refiting i done another compression test and i got 115psi, it still starts very well and runs better than before but when i go to pull off it often bogs down and stalls only with alot of rev's will it move. Any idea's? do you think its worth a piston kit or should i keep running it untill the rings have fully bedded in? thanks tom Quote
bansheesrtoys Posted February 12, 2011 Report Posted February 12, 2011 sounds like maybe your brakes are locking up or you have the e-brake on. does it roll easy or is it hard to push it? Quote
Tombola Posted February 12, 2011 Author Report Posted February 12, 2011 sounds like maybe your brakes are locking up or you have the e-brake on. does it roll easy or is it hard to push it? Its not too bad alittle stiff, although the back brake isnt on it still grabs alittle, Ive also replaced the axle bearings. Whats your views on compression i just done another test once it had cooled down and im sitting at about 120psi approx. Quote
bansheesrtoys Posted February 12, 2011 Report Posted February 12, 2011 with no mods 120 sounds good.i would look esle where. Quote
Jereme6655 Posted February 13, 2011 Report Posted February 13, 2011 so is there any modifications done to your bike? it almost sounds like you may be having a problem like if you have a set of aftermarket performance pipes on it but have not changed the pilot jet size.... Quote
armyvet Posted February 13, 2011 Report Posted February 13, 2011 It might sound like a stupid question but whats your current gearing?Some yoyo might have a 16/37 set up on there wIth a stock motor and 22in rears. Quote
