Hi all from across the pond!
I have a 04 banshee, I done a compression test and I got 90 psi although the quad started first kick and went like the clappers. Today I installed new genuine piston rings, the bores looked fine still had the original cross hatchings. After refiting i done another compression test and i got 115psi, it still starts very well and runs better than before but when i go to pull off it often bogs down and stalls only with alot of rev's will it move.
Any idea's? do you think its worth a piston kit or should i keep running it untill the rings have fully bedded in?
thanks
tom
