MorrisJL Posted February 6, 2011 Report Posted February 6, 2011 When I bought my banshee it came with a turbo twist throttle. Initially I like the twist throttle, but as I have become a little more brave riding on the trails of Reds Sands New Mexico (lots of rolls or loofs.. whatever they are called) I have run into a problem where holding on at higher speeds is causing me to goose the throttle when I don't want to. I nearly ate shit yesterday more than once due to this. My question... will switching back to a stock or aftermarket thumb throttle be as easy as changing the part and cable out and ensuring my throttle open/close adjustments are where I want them, or is there more to it. Just so you know... I tend to think things are much more complicated then they are. I would reference my Clymers, but from what I can tell it only talks to stock jobs, and my TORS is already removed. Quote
bansheesrtoys Posted February 6, 2011 Report Posted February 6, 2011 yep it's that easy. get a thumb thottle housing with a cable for a thumb thottle. then do like you said and check the slides and done. Quote
