zach45 Posted January 29, 2011 Report Share Posted January 29, 2011 where should i run the hose when i remove the bottle? Quote Link to comment Share on other sites More sharing options...
shakar Posted January 29, 2011 Report Share Posted January 29, 2011 (edited) if you want to continue to use the burp bottle, zip tie it to the frontend behind the bumper and between the shocks.thats where i stuck mine otherwise just let the hose hang down past he frame Edited January 29, 2011 by shakar Quote Link to comment Share on other sites More sharing options...
zach45 Posted January 30, 2011 Author Report Share Posted January 30, 2011 very good thanks Quote Link to comment Share on other sites More sharing options...
NOVIS Posted January 30, 2011 Report Share Posted January 30, 2011 if i can remember right, i just left the one overflow hose from the rad run down to the back to where the carb overflows are. and i also plugged the overflow that comes out by where the pump is. i only did this to make it easier to get at the carbs. Quote Link to comment Share on other sites More sharing options...
