if you want to continue to use the burp bottle, zip tie it to the frontend behind the bumper and between the shocks.thats where i stuck mine otherwise just let the hose hang down past he frame :cheers:
Edited by shakar
if i can remember right, i just left the one overflow hose from the rad run down to the back to where the carb overflows are. and i also plugged the overflow that comes out by where the pump is. i only did this to make it easier to get at the carbs.
