The gear on my current clutch basket started slipping after I got the hub nut torqued down so I'm in need of another clutch basket that the gear doesn't slip on, something that someone has actually used personally and can halfway guarantee that it won't slip. I have some parts to trade if you're interested just let me know by PM, email ([email protected]), etc.... Chris
On second thought maybe I should've put this in the "wanted" section or maybe not, I'm not sure. Mods feel free to move if need be.
Edited by bigblockbanshee
You just need new cushions man. If you really feel like you need a basket I've got a used billet basket I'd make you a deal on...
What are you asking for the used billet basket. Might be interested.
Ok you've got my attention, is there a "how-to" on how to replace them or is it pretty simple? I'd rather get by as cheap as I can so if I can just change the cushions I'll do that.
Check the repairs and mods section. There are some walkthrough's over there I believe are pinned that outline how to remove the backing plate and check out your cushions. Check your cushions first, they may or may not be bad, but based on your description that is where I would start checking for problems. You can get cushions from most builders. I'd give Kevin at Herr Jugs Racing a call first and see if he carries them.
- Jared
Its hard to change them on a stock basket. They rivet to the backing plate, has to be drilled off to check or change them. Id get on that billet basket Bigreds got for sale if I was you.
  • 1 month later...
