tipn22 Posted January 23, 2011 Report Posted January 23, 2011 can i transfur all 98 parts to a 87 j arm frame Quote
gotta_goatsfast Posted January 23, 2011 Report Posted January 23, 2011 What parts are you looking to change? Obviously A-arms from an A-arm frame wont bolt to a J-arm frame. Your CDIs and stators will be of different style, and I believe the hubs on the older banshees are not compatible with newer style wheels. Quote
tipn22 Posted January 23, 2011 Author Report Posted January 23, 2011 What parts are you looking to change? Obviously A-arms from an A-arm frame wont bolt to a J-arm frame. Your CDIs and stators will be of different style, and I believe the hubs on the older banshees are not compatible with newer style wheels. i have all parts from a 98 and the 87 is just the frame and j arms Quote
Larry's Shee Posted January 23, 2011 Report Posted January 23, 2011 The 87 won't have tabs for heel guards. Other than that everything will work. Can I ask why the switch?? Quote
bansheesandrider Posted January 23, 2011 Report Posted January 23, 2011 Use the j arms, don't put the foot guards on and use everything else from your 98 and you will have a running bike. Quote
tipn22 Posted January 23, 2011 Author Report Posted January 23, 2011 Use the j arms, don't put the foot guards on and use everything else from your 98 and you will have a running bike. i would'nt go to j arms if i had a chioce but i broke my a arm off at the frame hit a tree hard and this one was cheap and olny ten miles from home Quote
