spdracer71 Posted January 22, 2011 Report Posted January 22, 2011 Anyone ever had this happen?? I think that it either may be the waterpump seals OR the o-ring on that tube that goes into the side case?? Either way it made a mess so it will take me awhile for sure to flush all that mess out... THanks Quote
bansheesrtoys Posted January 22, 2011 Report Posted January 22, 2011 make sure you get the clutch cleaned quick and re oiled. coolant on clutch plates can somtimes screw up the clutch Quote
Wicked ATV Posted January 22, 2011 Report Posted January 22, 2011 Anyone ever had this happen?? I think that it either may be the waterpump seals OR the o-ring on that tube that goes into the side case?? Either way it made a mess so it will take me awhile for sure to flush all that mess out... THanks Replace the O-ring or water pump which ever is the issue. More likely just rolled the o-ring. Use an OEM one. After you replace it. All you Go get your Self a Thing Of ATF Trans oil. 1 quart is plenty but you can put as much as two if you wanted. Run the bike for about 15-30 min going threw all the gears back and forth. use the Clutch etc.... Drain that oil and it should chase most of the Old stuff that was left inside from the mess. Try to leave it Drip dry over night. Install new Fresh oil. We use this http://www.wickedatv.com/duportal30/home/detail.asp?iData=10676&iCat=302&iChannel=8&nChannel=Products. Then change the oil after your 1st trip and it should good to go.... Quote
spdracer71 Posted January 22, 2011 Author Report Posted January 22, 2011 Thanks a million everyone this has really helped out!!!!!! Quote
