ok so i need new intakes and everybody hates that boost bottle . Well i seen intakes without the holes even for the factory tube. My ? is , is it better to run without a tube or with the factory tube. and would their be any down fall to running with out it?or is this a drag racing mod?
It really depends on what kind of riding you do. If you're a trail rider, having the equalizer tube may give you a little better throttle response, but there is no performance gain/loss for the tube/boost bottle. If most of your riding is wide open throttle then the equalizer tube has no benefit to your setup
